Automatic Emergency Braking
Cybertruck is designed to determine the distance from detected objects. When a collision is considered unavoidable, Automatic Emergency Braking is designed to apply the brakes to reduce the vehicle's speed and therefore, the severity of the impact. The amount of speed that is reduced depends on many factors, including driving speed and environment.
When Automatic Emergency Braking applies the brakes, the touchscreen displays a visual warning and sounds a chime. You may also notice abrupt downward movement of the brake pedal. The brake lights turn on to alert other road users that you are slowing down.
![Green letter A within a circle Green letter A within a circle](https://www.tesla.com/ownersmanual/images/GUID-882E1FA4-0546-44C0-8820-98D46BC7DF6A-online-en-US.png)
Emergency braking in progress
Automatic Emergency Braking operates only when driving between approximately 3 mph (5 km/h) and 124 mph (200 km/h).
Automatic Emergency Braking does not apply the brakes, or stops applying the brakes, when:
- You turn the steering wheel sharply.
- You press and release the brake pedal while Automatic Emergency Braking is applying the brakes.
- You accelerate hard while Automatic Emergency Braking is applying the brakes.
- The vehicle, motorcycle, bicycle, or pedestrian is no longer detected in the front or rear of the vehicle.
Automatic Emergency Braking is always enabled when you start Cybertruck. To disable for your current drive, shift into Park and touch Controls > Autopilot > Automatic Emergency Braking. When disabled, the touchscreen displays a visual message.
