Is there a way to get a wire from the trunk into the interior on the floor between the front and rear doors? Is there a procedure that does not involve a lot of tear-down? Thanks
If there's not too much redundant wire, simple to tuck along the panel gaps with a pry tool. Check out YouTube for any videos regarding rear dashcam and go low along the baseboard trim rather than hi over the window
nkohlimd...thanks for the reply. I am just kind of nervous as to how to remove the trim...I don't know how much pressure to apply without breaking anything.' and then how to get back to the trunk. 1 shows how far I have gotten the wire from the dash. 2 shows where I want to get into the trunk near the red and black wires I used to tap into 12 Volts, and the 3rd shows the C pillar where I guess I have to pry or remove trim to get to the trunk.
