stopcrazypp
My point is you don't have evidence either that they are different. I have pointed at plenty of evidence they are likely the same:So what? That is in no way support his point that NCRxxxxA is the exactly the same cells that TM ordering from Panasonic...
- - - Updated - - -
And I explained why...
1) the cells are made in the same factory (in Suminoe, Japan, which makes both the NCR18650 and the NCR18650A)
http://www.rutronik.com/news+M5fb8cf031bb.html
2) The first 3.1Ah cell coming out of that factory made was handed in person to Tesla's CTO Straubel
http://www.engadget.com/2010/04/23/panasonics-3-1ah-batteries-to-be-used-in-the-tesla-model-s-hav/
3) The flagship 3.1Ah cell at the time was exactly the NCR18650A
4) they have the exactly same capacity (3.1Ah)
5) they are the same form factor (18650)
6) they both use the NCA chemistry
The only thing I don't have is Tesla or Panasonic explicitly saying that the 3.1Ah cell in question has a model number of NCR18650A (I don't expect them to EVER do that because no other EV manufacturer have ever done that either nor do they have a reason to), but it's very easy to connect the two.
The evidence you have is a PDF that talks examines Panasonic's NCA chemistry vs existing LiCoO2. It's not comparing "consumer" NCA vs "EV optimized" NCA as you are suggesting. It mentions the same chemistry is used in the 140 cell module that Panasonic recently released. That module uses 2.9Ah cells. And at the time of release (10/2009), the only 2.9Ah cell Panasonic was making was the NCR18650.
http://panasonic.co.jp/corp/news/official.data/data.dir/en091001-3/en091001-3.html
The cell tested in the PDF is a "400 mAh cylindrical type".
I would be convinced if you can provide a PDF document that compares different "formulations" of the NCA chemistry with extremely different cycle life under the same conditions.
- - - Updated - - -
But so do my "opponent"!
By the way, in a different thread he just tried to claim exactly the opposite, that automotive 18650 cells are very different from notebook/tablet ones! :wink::biggrin::biggrin:
Real wholesale price of kWh li-ion cells, at the end of 2012/start of 2013.
I did not say the opposite, I said this:
What I'm referring to is 18650 based on standard Cobalt based chemistries (Tesla being the only one that used it in an automotive application).Standard 18650 $/kWh have always been much better than other automotive optimized chemistries and cells.
There are other chemistries that use the same 18650 form factor:
(LiFePO4, same chemistry as the prismatic cells used in the Karma and Spark)
http://www.a123systems.com/lifepo4-battery-cell.htm
(LiNiMnCo, similar chemistry to GM Volt)
http://www.batteryspace.com/new-gen...50-rechargeable-cell-3.6v-2600mah-9.36wh.aspx
Notice they are completely different chemistries and in the automotive application all of the cells chosen are prismatic (not 18650).
