JomarR
I do not have the performance model which had me wondering if 15mm spacers would work up front. I have the 21x9.5 ubers with the stock 255/35 tires which rubbed slightly on the upper ball joint. I performed a test fit with 20mm spacers up front and it looks like they poke about 5mm more thank my liking. I am aware the wheel needs the 245/30 tires mounted on them as well which will give the wheel a more flush look I am guessing.15mm spacer would depend if you have a performance model or not, on the performance model the hat of the rotor is thinner therefor you might need an 18mm or a slip on to your 15mm if it’s bolted on. As far as camber goes my setup was on stock upper arm
Pic of actual test fit of 21”x9.5 Uberturbine with stock 255/35r21 tire and 20mm spacer
