Ability to avoid rollover?
Due to the low center gravity that is inherent in Teslas (with the battery pack being close to the ground), I wonder how often we will see this once the Semi has been rolled out. Also, what could be done (practically) to avoid the trailer from being the culprit in the future? Put an extended range battery pack in the floor of the trailer? Must See! This is the Moment a Semi-Truck Was Blown Off the Road by High-Speed Winds
Look here what a clever design, already from the 80's.
- More cargo capacity
- truck driver / FSD has far better visibility on what happens around the truck, particularly pedestrians and cyclists
- the command module = the battery pack
FLbDW8FXIAI5NNR
Reactions: cleverscreenam
