The 19x9.5 +32 might barely fit the rear axle, but more than likely you'll need a 5mm spacer to clear the suspension. Might be worth trying though.
I doubt the 19x9.5 +32 will properly fit the front axle, it's likely to rub the wheel wells on turns.
19x10.5 +22 is probably the same situation on the rear axle, might need a spacer to clear the suspension. Definitely will not fit on the front axle.
