Hi. I noticed with new updates that the High Speed fan switch is not the highest speed. To get a higher flow you need to change the temp. Why did Tesla do that?
I don't know what the deal is with the AUTO setting. It seems like you can change the fan speed. I was under the assumption that the AUTO setting would adjust the fan and everything based on the TEMP
You need to be in manual mode to switch between numeric set speeds. I think a recent update added speed settings in auto mode (low, medium, high), but it is a range of speeds (I presume it adjusts fan speed automatically within a range of speeds designated as low/medium/high).
