Alpharex released their new DoubleTap Dual Color LED Projector Fog Lights, I've been running these for the past few weeks - they perform great! Quick Double-Tap of the brights switches from white to yellow fogs, or from yellow to white. Completely Plug & Play.
Elevate your fog lights to a new level of performance with AlphaRex DoubleTap Dual Color LED fog lights for your Tesla Model 3 and Model Y! Bid farewell to lackluster stock fog lights that offer minimal visibility in challenging weather conditions and off-road expeditions. Experience the extraordinary capabilities of cutting-edge LED technology by complementing our headlights with our specially engineered LED fog lights.
AlphaRex's DoubleTap Dual Color LED fog lights come equipped with an LED tube for Daytime Running Lights (DRL) in white, seamlessly transitioning to vibrant amber for turn signal indications. We recognize the ongoing debate between white and yellow fog lights, as each color has its advantages in different driving scenarios. AlphaRex now presents the ultimate solution: DoubleTap Dual Color LED fog lights, featuring dual AlphaRex LUXX LED chips.
These remarkable chips emit a dazzling 6500K white output and a warm, effective 3000K yellow output. With our innovative DoubleTap feature, you can effortlessly switch between the two color outputs by merely flashing your high beam on and off twice within a brief 5-second interval. Moreover, our fog lights boast projector lenses that precisely focus the light output, ensuring optimal visibility and a wide-reaching light pattern.
Enhance your driving experience with AlphaRex and gain unparalleled clarity on the road. Upgrade to our Tesla Model 3/Model Y DoubleTap Dual Color LED fog lights to navigate the world like never before!
Fog Lights Technology
AlphaRex DoubleTap LED fog lights are a game-changing solution that eliminates the need to choose between yellow and white fog light outputs. With their innovative switchback feature, these fog lights allow you to effortlessly switch between a dazzling 6500K white light and a penetrating 3000K yellow light by simply toggling your fog lights on and off within 5 seconds.
Housing
AlphaRex DoubleTap Dual Color LED Fog Light are designed for both sleekness and performance. These fog lights boast a projector lens, replacing traditional chrome reflectors, ensuring superior light output and distribution for enhanced visibility in all weather conditions. With a modern full glossy black housing, these fog lights offer a stylish chrome-delete appearance, adding a distinctive touch to your . This upgrade not only elevates performance but also sets your vehicle apart from the crowd on the road. Upgrade your 's fog lights system with the DoubleTap Dual Color LED Fog Lights for improved visibility, enhanced performance, and a head-turning sporty aesthetic. Experience the perfect blend of functionality and style with these innovative fog lights.
Tesla Model 3, including Performance
Tesla Model Y, including Performance
Kits are in stock, drop by and pick up a set or have us install for you today!
![europeanautosource.com](http://europeanautosource.com/cdn/shop/files/17-23-tesla-model-3-20-24-model-y-doubletap-dual-color-led-projector-fog-lights-681518_1200x1200.webp?v=1715753129)
Alpharex - DoubleTap Dual Color LED Projector Fog Lights - Tesla Model 3/Model Y
Elevate your fog lights to a new level of performance with AlphaRex DoubleTap Dual Color LED fog lights for your Tesla Model 3 and Model Y! Bid farewell to lackluster stock fog lights that offer minimal visibility in challenging weather conditions and off-road expeditions. Experience the...
![17-23-tesla-model-3-20-24-model-y-doubletap-dual-color-led-projector-fog-lights-667621_1200x1200.webp](https://europeanautosource.com/cdn/shop/files/17-23-tesla-model-3-20-24-model-y-doubletap-dual-color-led-projector-fog-lights-667621_1200x1200.webp?v=1715753129)
![17-23-tesla-model-3-20-24-model-y-doubletap-dual-color-led-projector-fog-lights-561800_1200x1200.webp](https://europeanautosource.com/cdn/shop/files/17-23-tesla-model-3-20-24-model-y-doubletap-dual-color-led-projector-fog-lights-561800_1200x1200.webp?v=1715753129)
- Pros of yellow fog lights: Yellow fog lights have a range of advantages. Thanks to their longer wavelength, they excel in foggy conditions, heavy rain, or on dusty roads, effectively cutting through the haze for improved visibility. The yellow light is also easier on the human eye, making it ideal for detecting oncoming vehicles, particularly in challenging driving situations. Consequently, yellow light is commonly used in off-road lighting setups, making it the optimal choice for vehicles modified for off-road adventures.
- Cons of yellow fog lights: While yellow fog lights offer impressive benefits, there are some considerations to keep in mind. Compared to white light, yellow light may not provide the same level of brightness. If you desire a cohesive lighting appearance where your fog lights match the output of your headlights, yellow light might not be your everyday choice.
- Pros of white fog lights: White fog lights bring their own set of advantages. With their enhanced brightness, they enable you to navigate dark corners with confidence during nighttime drives. Additionally, white light seamlessly complements the output of your headlights, resulting in a visually cohesive and polished front-end appearance.
- Cons of white fog lights: However, it’s important to note that white fog lights have some limitations. Due to their shorter wavelength, they can produce glare in foggy or rainy conditions, which can be hazardous and reduce visibility in low-visibility weather situations.
Housing
- Compatible with 2017-2023 Model 3 and 2020-2024 Model Y with or without stock fog lights
- For Tesla Model 3 or Y vehicles equipped with stock projector headlights, the fog lights are designed for direct plug-and-play installation
- If your Tesla Model 3 or Y comes with stock reflector headlights and you wish to install our DoubleTap fog lights without upgrading to our NOVA-Series headlights, please select the option labeled "for stock reflector headlights."
- If your Tesla Model 3 or Y originally features stock reflector headlights and you are looking to upgrade to our NOVA-Series headlights along with DoubleTap fog lights, you will only need the headlights decoder to ensure compatibility of both
![53760485710_a3fc2a2a4c_b.jpg](https://live.staticflickr.com/65535/53760485710_a3fc2a2a4c_b.jpg)
![53759166882_76d81dca80_b.jpg](https://live.staticflickr.com/65535/53759166882_76d81dca80_b.jpg)
![53760069051_273828aa2b_b.jpg](https://live.staticflickr.com/65535/53760069051_273828aa2b_b.jpg)
![53759166992_a00b9d5986_b.jpg](https://live.staticflickr.com/65535/53759166992_a00b9d5986_b.jpg)
![53760069076_e55b1dd2db_b.jpg](https://live.staticflickr.com/65535/53760069076_e55b1dd2db_b.jpg)
![53760485790_2afa8216b3_b.jpg](https://live.staticflickr.com/65535/53760485790_2afa8216b3_b.jpg)
![53760485800_dfbbbf99b6_b.jpg](https://live.staticflickr.com/65535/53760485800_dfbbbf99b6_b.jpg)
