We live in Vermont. Current temps. 40F-60F. We just got our M3 and are wondering how much power we can expect to loose % wise while sitting overnight in 40% temps.
Thanks
Thanks
Around 1% with little temperature variation. However, if sentry mode is on it will drain much more. Also, I experienced more range loss while connected to WiFi but after owning it for a while I stopped bothering about it, so don't know if that's right or notWe live in Vermont. Current temps. 40F-60F. We just got our M3 and are wondering how much power we can expect to loose % wise while sitting overnight in 40% temps.
Thanks
If you do everything right and do not put up useless apps like TeslaFi or stats on the phone you can expect close to no loss over days.We live in Vermont. Current temps. 40F-60F. We just got our M3 and are wondering how much power we can expect to loose % wise while sitting overnight in 40% temps.
Thanks
Thanks
Unlike some have said, it isn’t “virtually zero.”
Yeah, I would say 5W is "virtually" zero, your TV will use more in idle or your lamp...When the car is sleeping, it consumes about 5W.
Anyways, not sure why you felt that you have to "re-summarize" what I said above and add "commentary"...
I turn off the car alarm (cabin heat protection also off) and actively turn off wifi before leaving the car, maybe that is the difference.It's interesting that your results are considerably lower than what I have observed
Do you have car alarm and wifi off? I noticed that when I leave them on , especially car alarm the drain is double. Test it with them off for referencehave cabin overheat protection off.
Yeah, short intervals is not good especially when the battery has cooled off and at the colder temperatures we have now. You should try it in the summer or in warm garage.I tried this overnight (no wifi, no car alarm, no COH protection) and if anything the drain is slightly faster. I'll leave it for a bit longer to see what happens I guess. A little difficult to compare over short intervals, since there is some randomness to the rate of drain.
Could be Sentry, Summon Standby. Anything that prevents the car from sleeping (though 6% overnight is a bit high).what would be the reason for loosing 6% power ovrtnight?
