Our first road trip. Darwin to Cairns.
In all it took 6 days using AC charging from Darwin to Mount Isa, and DCFC from Mount Isa to Cairns.
Our M3RWD was loaded with a Tent just in case, a space saver spare just in case, and a UMC with 10 amp, 15amp and 32amp 5 pin 3 phase plugs. Although the 10amp plug never got used, the 3 phase @ 7Kw did most of the work.
About to head back, and planning on 5 days. On the return we will also have a 16 amp 3 phase EVSE so we can charge at 11Kw.
Charging Stops
Pine Creek Pub - 7Kw. 5 Smilies for this place.
. We like this place and stop every time.
Mataranka Homestead - 7Kw. 4 Smilies.
. Would usually give 5 but the springs were closed that day so couldn't go for a swim
Larrimah - (2 - 5Kw) and an overnight stay. 4 Smilies
. Power issues are explained in Plugshare, otherwise lovely couple and an eclectic stop.
Daley Waters - 7Kw 5 Smilies
Did not have enough time to check the place out properly so plan to overnight on the way back
Elliott - 6Kw 3 Smilies
. Very helpful but nowhere to hide from the 40+ degree heat while charging for a couple of hours.
3 Ways Waramunga - 7Kw. 1 Smiley.
We overnighted to charge back to 100%. Charged $1.80 per Kw. With the room overnight dearest stop so far.
Barkly Homestead - 3Kw. 4 Smilies
. Only 15amp caravan plug so another overnight, but facilities is are a real oasis. Will be overnighting again on the way back.
RACQ Camooweal - (2 - 7Kw) 4 Smilies
. UMC overheated in the 40+ degree heat and car reduced charge rate. 2 hour stop turned into 5. Kudos to Dave for his assistance.
MT Isa - 50Kw 4 Smilies
Chargefox and overnight at local motel.
Cloncurry - 50Kw 4 Smilies
Chargefox
Julia Creek - 50Kw 5 Smilies
Chargefox. The extra smiley due to the station showing offline up until the day before we arrived
Hughenden - 50Kw 4 Smilies
Chargefox. Got to admit do like this DC fast charging
Charter Towers - 50Kw 4 Smilies
Chargefox. Walked across the road and stayed at motel overnight
Townsville (Cluden) - 50Kw. 5 Smilies
. Evie. This is a bloody petrol station with best facilities I have seen including a lounge area.
Cardwell - 50Kw. 4 Smilies
. Chargefox. Who ever thought that you would have to queue for a charger. A new first for us
Innisfail - 50Kw 4 Smilies
. Chargefox. Again another short queue but only 10 minutes.
Finally Cairns.
Been here for a little over a week and start the return trip tomorrow.
Charging Stops
Finally Cairns.
