Carbon Negative Cement
Discussion in 'Cars and Transportation' started by dpeilow, Feb 18, 2011.
  1. dpeilow
    dpeilow Moderator
    Winchester, UK
    If the EV deals with vehicle emissions, this sorts out the equally bad ones from infrastructure:
    New Cement is Carbon Negative
    Quite a significant development.
  2. evan
    evan New Member
    I first heard of a very similar product to this nearly 10 years ago - it was called TecEco EcoCement.
    We tried to get some, but that was only available in Australia. Fell back to hydrated lime instead.
    You can buy magnesium silicate boards though, as a replacement for the gypsum plasterboard. It's a superior product but also considerably more expensive.
  3. vfx
    vfx Well-Known Member
    CA CA
    I figure 10 years before it makes code for habitation construction. If ever.
  4. vfx
    CA CA
    #4 vfx, Feb 18, 2011
    Basaltt Rebar
    Also a significant development.
    Rock Rebar. Made from nearly-free volcanic rock. Does not rust so less capturing cement is needed too. 11 times lighter and 3 times stronger. Does not bend but can be made in shapes and there is also a fiberglass-style stranded roving version as well.
    This website gives the full advantages list:
