Hello everyone!
I just got a Model Y. I’ve been reading a lot about State of Charge. I learned that the general recommendation is to keep the battery charge between 30%-80% as much as you can. I only drive around 40/50 miles per day (sometimes even less) so I set my charge limit to 75%.
My question is about the lower end, when I come back home my battery level is usually between 55% and 65%. So should I let the battery level go a little lower (30% or 40%) and charge every other night? Or is it better to keep the state of charge as tight as possible and charge every night? (Even if it’s 60% to 75% every day)
Thank you so much!
Thank you so much!
