They're saying the upper control arm needs to be replaced. Will be putting it on the lift shortly but haven't said if this will be covered under warranty.
Repairs were covered under warranty. The also performed two other services at no charge. Interestingly, the charge port parts were listed as "Goodwill - Service".
Details:
Concern: Customer states: Creaking from right front at low speeds, mostly when braking/slowing down. This noise started
recently.
Replaced upper control arm and performed four wheel alignment.
Correction: Control Arm - Upper - Front - RH (Includes Alignment) (Remove & Replace)
Parts Replaced or Added
BOLT,HF,M10-1.5x87,STL[109],ZNFL,SMAT(1130701-00-A) 2.0
FR UPR CTRL ARM ASSY, RH(1044326-00-G) 1.0
Pay Type: Basic Vehicle Limited Warranty
Concern: Inspect HV Battery Positive Contactor Fasteners
Installed insulators and nuts for positive contactors. Up loaded measurements. Installed all components .
Correction: Install Insulators, Inspect Contactor, Fasteners Check OK
KIT, PENTHOUSE HV INSULATORS, M3(1467483-00-A) 1.0
Concern: Replace Charge Port Pin Deadfronts
Replaced Charge Port Insulator Pins With Updated Parts
Correction: Replace Charge Port Insulator Pins With Updated Parts
DEADFRONT,PIN,CP,M3,SERVICE(1470434-00-C) 2.0
Pay Type: Goodwill - Service
