I have looked extensively, buy can't find any one place with all the needed info. So I'll start the first thread.
Looks like the newer drive units use Dexron VI trans fluid. There are alot out there, but I prefer full synthetic, not all are. So I bought a case of valvoline dexron VI.
I'll grab some pics of my 2017 X100D when its in the air so you can see where the drain/fill plug is. It looks like the capacity should be about 2.4 qts front and rear. I've seen the capacities listed somewhere, so perhaps someone can fill me in if I am off. These all have aluminum cases, so the plugs should be torqued to 20.65ft-lb or 28NM. Apparently they are 8mm allen plugs, and the bolts that hold on the covers are all 10mm.
I will update this thread after I get the job done, but until then, I'll take any info anyone may have to make this more accurate. When I'm finished, I'll write what each unit took.
