First unnecessary massive tantrum (emergency brake) from M3
Discussion in 'The UK and Ireland' started by elecTED, Dec 4, 2019.
  1. elecTED
    elecTED Member
    Bristol, UK
    I guess it had to happen sooner or later.
    I have had a fair few phantom brakes of varying degrees of strength and quite a fair few unnecessary shrieking collision warnings but first time I’ve had an unnecessary emergency brake applied by car.
    Was very slowly approaching a gormless white (actually silver) van man who had his door open restricting the passage for vehicles to pass. I was about a couple of meters away from the car door almost coming to a halt when the car threw a massive wobbly and applied the emergency brakes with some force. The white van man gave me a dirty look as he closed his door and the M3 tantrum gave me a little fright too.
    Much room for improvement with all this fancy auto collision detection/warning/avoidance stuff.
  2. ewoodrick
    ewoodrick Well-Known Member
    Buford, GA
    I'm guessing that wasn't the emergency breaking, but the new one pedal driving function.
    Did the alarms go off?
  3. JCremonini
    JCremonini Member
    Bucks
    One pedal driving is to do with regenerative braking which uses the motor to slow the car down, when the accelerator is lifted, rather than apply the brakes. It won’t be that.
  4. ewoodrick
    Buford, GA
    And when you are right at the speed of stopping, the car applies the parking brake. When going very slow, the car prematurely applies the brake and can jerk the car a little.
  5. culverwood
    culverwood Member
    Herts
    Phantom braking has annoyed me dozens of times but the other day it saved me from a certain accident.
  6. elecTED
    elecTED Member
    Bristol, UK
    This was defo was an emergency brake as the car was brought to a violent halt. I think there was a warning shriek. One pedal slowdown is much gentler and gradual. Phantom breaking generally slows the car down (rather than bringing to a halt) with varying degrees of force and not really experienced the phantom at really low speeds.
  7. Alex987854
    Alex987854 Member
    UK
    Any details? Or even dashcam footage?
  8. culverwood
    culverwood Member
    Herts
    No dash cam but it was a slow speed incident and was the first time it had really slammed on the brakes as the car in front of me stopped rapidly while I was distracted.
  9. elecTED
    elecTED Member
    Bristol, UK
    If it saved you from an accident then it’s not phantom braking - it’s collision avoidance (using automatic braking).
    By its nature the phantom (braking) strikes in mysterious circumstance, one which real humans find hard to explain.
  10. Electric Dream
    Electric Dream Pilots the Millennium Milkfloat
    UK
    It's AEB. I've had it happen once when there wasn't going to be a collision. It can be a bit over-cautious at times.
  11. Yev000
    Yev000 Active Member
    Knaphill
    Hed it emergency brake twice for me. Both times when I tried to regen to hold and it deemed I would not stop in time before hitting the car in front. Both times I would have stopped by using the brakes a bit gentler.
    One time it didn't brake but gave alarms when giving way and ducking in a gap in parked cars and not stopping.
    Really not sure how much improvement can be had without a lot more image processing and computing within the second the situation arises.
