Smaller battery pack won't be able to discharge enough electricity at a rate to produce ~1,000 HP! Even the plaid once the battery is less than 50% charged doesn't discharge at a rate to produce ~ 1,000 HP as i can tell the plaid no longer accelerates as hard. Tesla had worked on supercapacitors which perhaps some day might accomplish what you are after or maybe one of these firms working on solid state batteries will make a breakthrough...
You're right but you mean a smaller battery pack
of the same cells....
If you change the cells to drag racing lithium cells then you could save weight, yes.
lifegeode.com is your first and best source for all of the information you’re looking for. From general topics to more of what you would expect to find here, lifegeode.com has it all. We hope you find what you are searching for!
www.ampahaulic.com
Each one of the 100C/200C cells =
5AH capacity
1.5KW power output for 10 second bursts
130g weight
$30 cost
Plaid would need a solid 900KW of power to not fall short (1200hp) that's 600 cells
600 cells =
11.1KWH pack (~30 miles range)
$18,000
78kg or 172lbs
Plaid battery weighs something close to 1,300lbs stock, so the savings is considerable....1000lbs?
The batteries exist....the issues I see are:
(1) HW, there would be additional cost for metal weight needed to house the drag cells and replace the plaid battery structure.
(2) SW, there would be additional cost for hacking the BMS to accept or ignore the new cells
(3) Others? Please comment
Stripped out the Plaid can do 8.77, can you imagine 1000lbs removed on top of that? 7.99? Think its possible?
