Hi All,
I first got into my Model Y about 8 months ago. As we all know there’s a learning curve involved in the transition, but I drive a lot for work… every day. I’m now pretty dialed-in on what the car can and cannot do, and my confidence level is high because correct split-second reactions are second nature at this point. Driving gets more exciting and overall, much easier the more the advantages of the car are mastered. That said, there is one situation I find more difficult to deal with compared to my old gas guzzler… ice, especially on a steep downgrade.
I live in the mountains, and 20 + winters later understand what to do and what not to do to stay out of the ditch on the side of an icy road, although this is my first winter in an e-vehicle. The key factor is maintaining traction, and unless you’re running studded tires (which is not an option if you run dry highways and snowy mountain roads) it doesn’t take much to lose it on ice. A small pulse of power or a touch of the brakes at the wrong moment can put you into an uncontrollable spin. In a conventional car you have the option of simply releasing the gas pedal (and not touching the brake) when you’re on the edge of busting loose. But in an electric vehicle, when you let off the accelerator the motor(s) inherently brake, and that’s problematic.
I’d love to hear your thoughts on this and maybe pick up a pointer or two.
Thank you,
Johnny
Thank you,
Johnny
