wwhitney
For what purpose and what code? For crawlspace ventilation, it's not immediately clear to me:Those look great; do you know if they are code compliant in California?
CRC R408
From a performance point of view, the question is whether the closed vents in cold weather would allow an excess build-up of ground-source moisture. If you have a vapor retarder on your crawlspace soil, that would be less of a factor, although still non-zero.
Better than temperature control would be a vent that opens and closes based on relative humidity, although that would have to be powered. The best controller would probably use outdoor temperature and dew point vs crawlspace temperature and dew point to maintain the crawl space RH below 60% while maintaining the temperature as close to 70F as possible.
I favor an R408.3 unvented crawlspace.
Cheers, Wayne
