Lithium Air Battery?
Discussion in 'Battery Discussion' started by Jaxcoffee, Mar 13, 2014.
Tags:
  1. Jaxcoffee
    Jaxcoffee Member
    Paso Robles, CA
  2. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Tesla has patents to capitalize on this.
  3. ItsNotAboutTheMoney
    ItsNotAboutTheMoney Well-Known Member
    Maine
    AFAIK:
    Very high volumetric energy-density
    High to medium(?) gravimetric energy-density (works by oxidation, so gets heavier as the metal oxidizes)
    Low power density
    Low efficiency (generates a lot of heat in use)
    Low cost of manufacture.
    Short life.
    Easy recycling
    Seems like it has good potential for use as an occasional-use range extender.
    Tesla has a patent on the idea of a hybrid li-ion/metal-air battery, although it's a pretty obvious idea so could just be to save time fending off patent trolls.
  4. jandkw
    jandkw Member
    Cary, NC
    There are quite a number of viable battery development projects going on in the industry worldwide including Lithium-Air. I know IBM is working on the Lithium Air project (in Almaden Research Lab.) called Battery 500 (500mi/charge) since 2009 and targeted 2020 for production.
  5. kingwellenergy
    kingwellenergy New Member
    中国
    Such technology could transform regular electric vehicles, as well as plug-in hybrids and range-extended electric cars.
    The typical plug-in hybrid goes 10-20 miles on its smaller battery, but this could leap to 30-60 miles should VW's lithium-air chemistry prove viable.
    Full battery-electric vehicles would comfortably leap to 200-300 miles, maybe more if energy efficiency is towards the top end of VW's estimates. Alternatively, smaller, lighter battery packs could be used to match the range of current electric vehicles--beneficial in city cars, for example.
  6. curiousguy
    curiousguy curious member
    Michigan, United States
    this technology has major inherent drawbacks (as well as promises). currently the degradation of battery components by superoxide radicals formed during charging hinders progress in the field. IBM was a leader in Li-air research but they recently announced they will "diversify" to Na-air. Other relevant companies researching this are Liox and Polyplus. Also, JCESR (a govt initiative...) prefers Li/S and flow batteries over Li-air. basically until this problem with radicals being formed in the electrolyte is solved there is no commercialization on the horizon. This is not a trivial task. To put this in perspective, radicals are also the culprits for aging and cancer.
  7. Kandiru
    Kandiru Member
  8. Matias
    Matias Active Member
    Finland
    "Despite the significant progress made by Prof Grey's team, they say a commercial lithium-air battery is at least 10 years away."
  9. Cyberax
    Cyberax Member
    Seattle, WA
    I worked with ex-lithium-air battery scientists. It's a holy grail of battery technology - theoretical density of Li-Air batteries is about the same as that of gasoline. So a Tesla-sized Li-Air battery could feasibly have several thousands miles of range.
    There's just one catch - nobody can make a reliable Li-Air battery. There are many way too many hurdles.
  10. curiousguy
    This paper brings significant knowledge to the li-air field. The end product of discharge is not li2o2 but lioh. Which means the radicals which were previously eating the electrolyte are now reacting with water in a stable manner. Grey's group shows 2000 cycles with a capacity of 1000 mah/g and a discharge voltage of 2.7V. The hysteresis to charge also decreased to 200mV or so. This is basically at the level lithium sulfur batteries were a few years back. The only problem is (well disguised in the paper) the capacities per cm2 are very low, about 0.5mah/cm2 from my calculations based on the numbers given in the paper.
