G GGMk Member Jun 20, 2018 23 13 Kirkland Sep 26, 2018 #1 Sep 26, 2018 #1 I just noticed that the metal panel between the dashboard and windshield is bent. Anyone having a similar issue? Attachments 2C09FE03-F8B1-46E3-BFD7-415067B3F4E7.jpeg 361.5 KB · Views: 105
P85_DA Active Member Supporting Member Apr 25, 2015 4,272 3,423 CA Sep 26, 2018 #2 Sep 26, 2018 #2 GGMk said: I just noticed that the metal panel between the dashboard and windshield is bent. Anyone having a similar issue? Click to expand... Nope
G GGMk Member Jun 20, 2018 23 13 Kirkland Sep 26, 2018 #4 Sep 26, 2018 #4 Do you think it is fixable if I conplain to the SC or should I just deal with it?
P85_DA Active Member Supporting Member Apr 25, 2015 4,272 3,423 CA Sep 26, 2018 #5 Sep 26, 2018 #5 GGMk said: Do you think it is fixable if I conplain to the SC or should I just deal with it? Click to expand... Fixable I believe that is a metal piece it may bend back
M mxnym Active Member Mar 9, 2018 1,572 785 Bloomington, IN Sep 27, 2018 #6 Sep 27, 2018 #6 GGMk said: Do you think it is fixable if I conplain to the SC or should I just deal with it? Click to expand... Definitely fixable, can be replaced if not unbent. Warranty is another question, depends if it was delivered bent or how it got bent.
spectrum Member Supporting Member Jun 17, 2018 527 557 Atlanta Sep 27, 2018 #7 Sep 27, 2018 #7 Mine is not bent. However, I feel like mine is under pressure as it clicks/creaks once in a while. Reactions: P85_DA
ithinkmac Member Oct 28, 2013 245 215 SF Bay Area Sep 27, 2018 #8 Sep 27, 2018 #8 Mine was bent, albeit a lot more slight than yours. I have the SC replaced it on one of my visits. -ThinkMac-
