Micro-jet turbine REEV?
malcolm
3,072
1,757
FEATURE-Jet turbine could power hybrid electric car | Reuters
With automakers racing to develop the most efficient, environmental friendly cars with minimal emissions, the concept of turbine-powered electric vehicles is not new.
But ETV Motors, a private company based just outside Tel Aviv that has raised some $12 million in investments, says it has found a way to make it commercially viable.
It says it has developed a micro-turbine engine to act as an on-board charger and a high-density battery that can power a vehicle for about 60-80 km (35-50 miles) on one charge.
TEG
Teslafanatic
Aug 20, 2006
21,965
9,194
That idea has been done in prototype form a few times.
Turbine powered series-hybrid EV1
The Williams Gas Turbine Power Unit uses a single-shaft, recuperated gas turbine coupled directly to a high-speed permanent-magnet AC generator. This turbine operates between 100,000 and 140,000 rpm, delivering up to 40 kW of electrical power.
Some more:
200MPG from the 200 MPH Micro-Turbine Velozzi Hybrid
ETVMotors announces funding for range-extended EV w/micro-turbine
Ford S-Max based micro-turbine plug-in series hybrid [w/VIDEO]
Turbine powered Series Hybrid S-Max - NASIOC
Green Car Congress: Propane Series-Hybrid Buses for Knoxville and Gatlinburg
Green Car Congress: Capstone Turbine Successfully Demonstrates EPA and CARB 2010 Diesel Engine Emissions
TEG
Teslafanatic
Aug 20, 2006
21,965
9,194
I wonder if they have solved the noise issue. Such high RPMs tend to produce a lot of noise.
Here is another micro-turbine generator:
TMA Power Co.
TMA Power, LLC will introduce to the electric power generation industry a 70 Kw, 3 phase 480volt a/c compact, low weight, mobile, multi-fuel, low noise, no vibration, low emission hybrid-microturbine. Unit operates at variable speed dependent on power demand.
vfx
14,790
47
CA CA
Saw/heard Jay's EcoJet the other day. Got to be one of the coolest sounds to ever come from a car. But I could not imagine the insanity of every car on the road making that din.
