2021 Y that has acted just fine until 2024.8. Ever since, it fails to read speed limit signs higher than 60mph on anything other than 4 lane divided highways. I can see the lower signs on the display, but higher ones don't show. I keep doing bug reports but I'm not sure that really does anything.
This is a big problem when using AP here in Texas because it will only let you do 5 over on these roads. I've had the FSD trial this month, hopping that would have fixed it, but no. At least with FSD you can adjust more than 5 over, so when the last sign the car read was 55, but the speed limit is actually 70, I can push it up. But now my trial is over so...
Is anyone else having this issue? Is it just certain models? Does a newer firmware correct it back to the way it was (working)?
