Tesla Model 3 19” Winter Tires and Rims . Condition is Used. Local pickup only.
Used set of Pirelli Sottozero 3’s 235/40 R19 mounted on Axis MS Bright Silver Turbine Rims. Used for 2 seasons Nov - Apr. They have at least one season, maybe 2 left. Some road rash on one, repaired with minor nicks and scratches. Very clean and look great on my Tesla model 3 LR. Bought premounted from the tire rack. Includes original lugnuts.
Specs Below.
Tire Specs
SpecificationsPIRELLIWINTER SOTTOZERO 3Size: 235/40R19Service Description:96V Load Range: XLUTQG: NoneMax Load: 1,565 lbsMax Inflation Pressure:50 psiTread Depth:10/32"Tire Weight: 22 lbsRim Width Range:8-9.5"Measured Rim Width:8.5"Section Width:9.5"Tread Width:8.3"Overall Diameter:26.4"Revolutions Per Mile:Country of Origin: ITALY
Rim Specs
Axis MS 19x8.5
Offset 35mm
5-114 bolt pattern
UPDATE - Will not fit Model 3 with PUP. PUP has a stepped hub which these rims will not fit over.
Specs Below.
Tire Specs
Rim Specs
Axis MS 19x8.5
Offset 35mm
5-114 bolt pattern
