Hi, I've noticed that my driver side door trim panel rattles at certain vibrations (on the road and using a tone generating app) I wanted to line the edge of the plastic with something so that it doesn't rattle against the metal. Just to be clear, the sound is coming from the interior door plastic housing rubbing against the metal door frame. When I put pressure on the plastic door housing, the sound disappears. What's the best type of product to use? Should I use rubber? Should I use a neoprene adhesive product? I've seen something called a car door trim pinch seal strip. Whatever I use, I don't want it to introduce new sounds, so Im hoping that the product I use won't cause new squeaks.
