most efficient regen speed measured
David99
5,576
9,682
Nomad (mostly US)
A discussion in the Model 3 section was around the subject whether short and strong regen was more efficient than long and lower power regen. In theory the motor/inverter would be more efficient at higher loads thus stronger, shorter regen would gain a little more energy back.
I wanted to dig a little deeper and used 'Scan my Tesla' to read the efficiency at different levels of regen. It shows the efficiency directly as a percentage so it was straight forward to measure. I don't have a Model 3 so I did these tests with my Model S RWD 85.
I measured the efficiency at 45 kW of regen power and at 15 kW of regen power. At 45 kW the efficiency is around 87-88%. At 15 kW the efficiency is 83-84%. That alone isn't a big difference. I'd say, small enough to not really care one way or another. But there is more. While I was doing tests, I also noticed that when the car is in D(drive) the car uses aprox 400 Watt more power than when in P or N. It seems the drive unit consumes about 400 Watt just being turn on regardless of motion, acceleration or regen. At 15 kW this is 2.7% loss. At 45 kW that's 0.9% loss. In other words, because there is a constant load, the efficiency looks worse at lower power than higher power. The base load makes up a larger portion. It means the true efficiency difference is aprox 2% less.
Strong and short regen might have a very slight efficiency advantage on the motor/inverter. OTOH regenerating earlier with less power means your average speed is a little lower (you are starting to slow down earlier). That reduces air drag meaning you have a little more kinetic energy available for regen. All things considered both method should be almost exactly even.
Bottom line: For efficiency it doesn't matter if you use stronger and shorter regen vs longer and weaker regen. Do whatever you feel like!
BTW, if you wondered by regen power changes with speed:
The maximum regen power I was able to measure was 72 kW when going 110 mph and letting go of the accelerator. From there on regen gradually decreases with speed down to zero at about 3-4 mph. Tesla adjust the regen power with speed automatically. This makes sense as higher speeds 'contain' more energy. 50 kW of regen feels light at 80 mph, but it is very strong at 40 mph. So Tesla adjust the regen power down with speed to keep the feel of deceleration consistent.
That's a some very interesting findings in regards to efficiency. I'm wondering how they calculate the "efficiency" number.
Academically its as follows:
Recovered Regen Energy and
Total Regen Energy =
Kinetic Energy at the start of the regen - Kinetic Energy at the end of the regen event - drag energy consumed during the whole event
Regen Efficiency = Recovered Regen Energy / Total Regen Energy.
I'm surprised that Tesla has a method of calculating total regen energy and that its reported on the CANbus.
Regarding the regen efficiency with fast decel vs. slow decel, I found the answer in an old blog post I'd read a bunch a long time ago. AC Induction motors have a wider efficiency band than PMAC synchronous motors found in most other EVs. While what i said in the other thread may be true for other EVs with PMAC SM, its not true for induction in the Model S. More confusing now since the Model 3 has both....and which one is used when.....
Induction Versus DC Brushless Motors
In contrast, induction machines have no magnets and B fields are “adjustable,” since B is proportionate to V/f (voltage to frequency). This means that at light loads the inverter can reduce voltage such that magnetic losses are reduced and efficiency is maximized. Thus, the induction machine when operated with a smart inverter has an advantage over a DC brushless machine – magnetic and conduction losses can be traded such that efficiency is optimized. This advantage becomes increasingly important as performance is increased. With DC brushless, as machine size grows, the magnetic losses increase proportionately and part load efficiency drops. With induction, as machine size grows, losses do not necessarily grow. Thus, induction drives may be the favored approach where high-performance is desired; peak efficiency will be a little less than with DC brushless, but average efficiency may actually be better.
Reactions: David99
Cool data, thank you for sharing!
It may not be that Tesla is adjusting the regen power, but that the same regen force (deceleration) will cause power to scale with the speed. (they could also be adjusting the g load with reduce jerk at the end).
Work(energy) is force over a distance, power is work over time. The same amount of regen force at a higher speed is inherently more work, and thus more energy and power. Twice the speed means twice the distance so twice the work/energy preformed in the same time so twice the power.
You can ask the guy who wrote the 'Scan my Tesla' app exactly how he does it. It's coming directly from the inverter I believe.
The car also keeps track of energy going out of the battery and going into the battery. Makes sense as that's necessary to keep track of the state of charge at any time. It is able to tell exactly how much energy came back from regen. It even has a counter for the total lifetime of the battery. When driving through the city I usually get about 30% back through regen. The more freeway driving, the less regen. On road trips with mostly freeway driving, the regen percentage is around 6%.
I really hope soon we will have access to the Model 3 CAN bus.
