MYP 275/35/21 & 295/35/21 w/ 20mm spacers
I'm currently running 265/40/21 and 295/40/21 with 10mm spacers front and rear. No rubbing, fitment is nice, but could come out a bit more, especially in rear.
I was wanting to go down a little bit in tire size to 275/35/21 and 295/35/21 with a 17mm spacer on the front and 20mm spacer on the rear.
Has anyone here ran a 275/295 setup with 20mm spacers on a MYP, any rubbing???
Stock 275/35 no spacer vs 295/40 with 10mm spacer...
Current Fitment 265/40 295/40 10mm spacers front & rear...
it looks great! do you really need a spacer to 295/40/21 in the back? i can imagine you would need it if you run 275/40/21 in the front.
this is mine with Spacers running 275/35/21 front and 295/35/21 rear with spacers. I can't remember the size of my spacers but the back ones are larger.. Maybe a little too large but I actually like the look. It does rub a bit in the rear on big bumps or if i have adult passengers, but overall not too bad.
Reactions: Skavatar
are you on stock suspension right now?
Looking into 275/35/21 front and 295/35/21 rear with spacers but I have lowering springs installed
Man… your setup looks awesome, too bad about the rubbing on rear. I was thinking of going 295/35 on rear since I have 25mm spacers but now I’m considering 285/35. I have passengers often cause I drive rideshare. Regardless it looks amazing. Thanks for the share. What side skirts do you have on yours? I always like the detach diffuser blade look at the corners. Also here a pic of mine with 25mm spacers on stock Uberturb wheels.
im seeing negative camber, inside edge of tires wearing....is this by design by Tesla?
did your spacing make this worse
Love this. It's almost identical to how I've envisioned my black MYP to look once finished. I'm about to install H&R lowering springs with rear camber arms and a staggered 17mm/20mm spacer combo on stock Michelin Pilot's (255/35/21 front & 275/35/21 rear). Once those wear out I'm going to look into picking up some wider rubber. I've always thought the 275/35/21 front and 295/35/21 would be perfect, so hopefully there won't be any issues.
can you share the brands and models for the arms and spacers? once on the 275/295s, report back with photos
thanks
