From Abstract Ocean for one of their products:I have a question: where did the blue data port connection go that used to be here?
On the 4680 MY AWD there's nothing in that same location...
Model Y Compatibility Note: The OBD port has moved in some Austin-built Model Y's. If you have a mid-range (LFP battery), Model Y, then you will need the new LFP harness which you can select from the accessories below. If you don't know which model you have, simply remove the panel at the back of your center console, if there's no blue OBD connector there, you will need the new LFP cable).
They say LFP, but they really mean 4680. So you need a different cable to connect in the right A pillar area. (They have a video showing it.)
