This is a brand new OEM Tesla Cycle outfit that is a L on the bib and an XL on the shirt. I bought 2 of these when they were available a few years ago. I am asking $300 for the pair or best reasonable offer.
Weight 190 grams (size medium)
Fabric Durable, longwearing nylon under the chamois, compression Power Lycra on the printed panels for good looks and muscular support. Breathable, wicking poly elsewhere to regulate temps.
Mesh Upper Bib Bibs are for allowing you to belly breath more effectively – low contour gives great breathability as well.
Construction Nine panels let us put the right material in the right place. Absolutely no cross-seam in the chamois, making the most comfortable contact point possible.
Chamois Anatomically correct (gender specific) high-density open-cell all-way stretch foam padding with two layers X-TRACT Fabric against the skin. Ultra fast drying with great breathability.
Stitching Flat lock seams: stronger, more comfortable, and better looking. Just like you, right?
Race Compression Studies show supported, stable muscles last longer. Rest up for the bunch kick.
Tagless We’ll save you the work of cutting out the tags and labels.
Gripper Highest-quality silicone won’t crack over time and keeps shorts in place.
Care Instructions Wash in cold water, hang dry and fold. Clothing will survive several spins in the drier, but it’s advised to hang dry for optimal results. Wash items with velcro in a separate cycle. Velcro is the single biggest destroyer of performance cycling wear.
