Thank you for the heads-up on this potentially very useful display.
I'm using a RPi 3B+, running Linux 9, (stretch).
I followed the installion guide in readme.md.
I had problems from "docker exec -it influxdb influx" and had to pull docker from
https://get.docker.com/
pi@GDU-ESP-6912:~/Powerwall_Monitor $ docker exec -it influxdb influx
Got permission denied while trying to connect to the Docker daemon socket at unix:///var/run/docker.sock: Get
http:///var/run/docker.sock/v1.40/containers/influxdb/json: dial unix /var/run/docker.sock: connect: permission denied
pi@GDU-ESP-6912:~/Powerwall_Monitor $ sudo docker-compose up
ERROR: Version in "./docker-compose.yml" is unsupported. You might be seeing this error because you're using the wrong Compose file version. Either specify a version of "2" (or "2.0") and place your service definitions under the `services` key, or omit the `version` key and place your service definitions at the root of the file to use version 1.
For more on the Compose file format versions, see
Compose file version 3 reference
I copied powerwall.yml to the default docker-compose.yml and ran again....
ERROR: The Compose file './docker-compose.yml' is invalid because:
services.influxdb.volumes contains an invalid type, it should be a string
services.telegraf.volumes contains an invalid type, it should be a string
services.grafana.volumes contains an invalid type, it should be a string
services.influxdb.ports is invalid: Invalid port "{'target': 8086, 'mode': 'host', 'published': 8086}", should be [[remote_ip:]remote_port[-remote_port]:]port[/protocol]
services.influxdb.ports contains an invalid type, it should be a string, or a number
services.grafana.ports is invalid: Invalid port "{'target': 9000, 'mode': 'host', 'published': 9000}", should be [[remote_ip:]remote_port[-remote_port]:]port[/protocol]
services.grafana.ports contains an invalid type, it should be a string, or a number
I've checked on the git supository and the source was updated on the 16th. Dec 2019, so it should be current.
I can't get the database running so I'm stalled.
Has anyone else tried this?
