P85 2013 will not start lots of codes
Hi I have 2013 p85 great car for just over a year range is only 127 miles hv battery obviously has some issues I live on a small island range has not been much of a problem I recharge with 220 volt home charger last Tesla update August put a lot more items on the service page the car was running perfect I parked up and plugged in next day tried to start car started then died then started again but would not drive ,I checked 12volt battery 12.7v so I charged up with 110 volt battery charger car then proceeded to give me faults it will start up but I cannot select drive ac doesn’t work screen seems slow any thoughts thank you for any help
No change left car for 24hours reconnected battery no change thinking it is the hv battery pack will have to start deciding if its time to drop the pack the car is like brand new would be criminal to just park it up and leave it in the bush to die
Hi I think you may well be right the car was running good but obviously when I plugged charger in some more cells may have decided to go on strike if I lived in USA we would change it out but where I live a 2000lb battery change is difficult will keep you informed
