That seems awfully slow. Did you heat the tires up to make sure they were up to temp? They may work better if adequately warmed up.
You might be better off with a PS4s for what you are doing. It might help to post other parameters from your run such as the time slip so we can see the 60' times to see how it is launching. Did you use drag strip mode? What stance? Etc.
