Yup, a Kill-A-Watt would work too. And like you, I can see the Fac on the Sunny Data Control screen from all the inverters.
After reading this, I decided to test my system. It is also on version 1.25.0
At about 9:35am, I had 3kW of solar production, 0.8kW house load, and the PW was at 92% and charging. I opened the main breaker, and the PW took over the house load. Solar was disrupted for 5 minutes due to the brief outage created by opening the main breaker. After solar production resumed, the frequency stayed around 60.04Hz until the PW reached 98% at 10:20am, where the frequency then rapidly increased to 60.54Hz at which point my inverters shut down.
I continued to let it run, and the frequency dropped to about 60.03Hz in 2 minutes. After 5 minutes, the inverters came on and more charging for about 5 minutes, until the PW increased the frequency again to 60.55Hz which shut the inverters off. At this point, I closed the main breaker to restore utility power.
I never saw the frequency go above 60.55Hz, and that is enough to shutdown my SMA string inverters. I also received a notification on my phone when the utility power was off and again when it was restored.
That sounds great for your system. However, I had a different experience on October 16th. We had a power outage for 1 hour and 23 minutes that started just before I left the house in the morning. There was a momentary dip in the lights and the Powerwalls were apparently powering the house just fine. The SOC was about 48%. I checked the Tesla app when I got to the office and found that the solar was not generating any more. It stopped briefly at the cutover and then generated for about 20 minutes before my Enphase inverters gradually all went offline and recorded errors for AC Frequency Out of Range. They did not come back online until the grid power returned.
This is on 1.25.0. I submitted a trouble report to the Powerwall Support e-mail but I haven't heard back yet.
In another test I did a few days ago however, when I purposely overloaded the PW2 with no grid power, the PW2 shut down and the generator came on as I expected. I also expected that the PW2 would use the solar during that downtime to up its SOC from ~50%. However in the 20 or so minutes I waited, the solar and the PW2, which was in standby, never made the connection and neither came online until after I restored grid power. During that time, the solar inverters reported no voltage, so the PW2 was not trying to make contact with the solar. It was not a frequency issue. That was a disappointment. Perhaps without a load, the PW2 does not feel the need? I had a different result when I manually threw the generator transfer switch without overloading the PW2. In that case, the PW2 and solar played together nicely while the house was being powered by the generator. Obviously more testing is necessary, but getting the PW2 out of standby without the grid up may be an issue.
Any updates on this?
If so :
1) Will the new gateway release do anything to change it?
2) Has anyone found any additional UPS systems that might work?
3) Has the Powerwall 2 been updated to resolve this frequency issue that normal UPS systems will work?
