The roadster is just a cool mass simulator. Its batteries aren't used for anything.
Apparently the stage and the roadster stay together forever.
The reasoning is when a payload is ejected it receives something like 1 m/s separation push that sounds like little, but over a day it adds up to thousands of Kms, eventually becoming millions. USAF tracking sees a single object (roadster+upper stage). I could be wrong and eventually see an additional object.
The roadster is being cataloged by astronomers:
Jonathan McDowell on Twitter
The roadster has been cataloged by NORAD:
AF Space Command on Twitter
43205 TESLA ROADSTER/FALCON 9H 2018-017A PAYLOAD
In fact, SpaceX chose the (launch preparation) path that allowed them to spend as little as possible on the integration and preparation of the Roadster for launch. Even adding solar panels to it would have costed millions USD (done in a way that would have a high likely hood of working).
SpaceX must keep its high profile, we know what we're doing and plan things well mantra. There are always unknowns but they are (mostly) predicted. You don't add hardware to the system without proper simulation and testing.
Launch environment typically subject payloads to 5 or 6Gs. Anything that looks sturdy on the ground might not handle even 3 Gs. Far more complex than meets the eye.
The roadster is not planned to ever return to land. Its an orbit that's like a comet that flies between earth distance to the sun and beyond Mars distance. That doesn't assure everytime it returns to Earth altitude (perigee) that Earth will be here too. Because they have different orbital periods. Earth's is one year. The roadster is over 2 years.
It is predicted to pass somewhat close to earth in 11 years, but not flying around the earth.
PS: I'm not a rocket engineer, astro physics degree or any other expertise where you do study this stuff. Just know too much math and physics for high school but too little to be a physicist. Any corrections are welcomed.
