No chance. Rockets don't carry propellant to dump it. Everything has a use. Starship is exceptional because of its size and the fact that SpaceX is willing to lose experimental vehicles. Everyone else focuses on every flight being perfect.Do F9 or Heavy ever dump significant amounts of propellent during flight?
Remember depress events during testing? Those are the vents. Here's a beautiful venting shot during the last attempt at a wet dress rehearsal.Any ideas where the LOX vents are?
I didn't lend much credence to the idea that venting broke something because the venting process is so simple. The only way I can see venting breaking something is through the violence of the vent. Venting on the ground is venting with 1 bar of back pressure (the atmosphere). In space, there's no back pressure and they may not have accounted sufficiently for that. Venting in a vacuum is not normal.
Oh, sure, there's propellant leakage because valves aren't perfect, but there's no dumping, per se.Hmmm... I guess the images I seem to remember of previous flights were plumes of exhaust and/or during things like engine cutoff when there was some slight amount of unburned prop that escapes the nozzle.
Oxidization is often an exothermic reaction, so throwing something into a pure oxygen environment can result in the release of a lot of energy. That energy will help the reaction along.So, oxygen by itself isn't flammable. But it is reactive enough to make many things burn that normally wouldn't.
Even a spark across some electrical contacts could be enough to get things going. That would start aggressively oxidizing some copper wires, or the plastic, or something else nearby, and you're off to the races. This was the tragic sequence of events behind the Apollo 1 fire.If your theory holds true and O2 found it's way back inside the structure of the ship somewhere, perhaps inside the engine skirt where there was even the slightest unburned methane in the exhaust, or even other material (wiring, aluminum structural material, insulation, etc...) I wonder if that's what went up in "a combustion event and subsequent fires" as the report says....
I'm not sure what Alex is concerned about. You've got a chaotic environment because of the LOX tank blockage. The computers had time to detect partial blockages and cleanly shut down those engines, while other engines were completely blocked and blew up.Also, this is a good point:
My reading of the info from SpaceX is that the leaks they refer to are methane leaks which then combusted with the LOX being vented.Good point. Maybe the the venting action popped a line somewhere causing a "leak" in an unplanned area.
Here's a guy playing with pure oxygen at low pressures combined with heat to cause ignition. He starts with some experiments with brown paper, but I'm linking to an experiment with steel wool. He runs a current through it to see how it reacts in that low pressure, pure oxygen environment.
Earlier in the video, he mentions that the silver strips shown are actually made of silver because they won't burn in an oxygen environment. He also mentions that copper and stainless steel will.
I feel like an history student from the local community college who wandered into a Math class at MIT.Cool video... it makes me wonder what the "effective pressure" on the ship at the altitude was when it vented the O2.
Also, one of the reason oxyacetylene torches can cut steel is the "oxy" part. That and why smoking around your grandma in the oxygen tent at the hospital is frowned upon...
My interpretation of SpaceX's statement was that it was a regulatory thing. They were trying to have little to no fuel at time of landing/splashdown. So they were purging the excess fuel to make that happen. Here is the pertinent statement:I feel like an history student from the local community college who wandered into a Math class at MIT.
Why would do you have to vent LOX vent if there is no payload? I don't see the connection. If they ended up with excessive LOX at the end of the burn, for whatever reason, why bother venting it? Rather why not take just about enough LOX commiserate to the payload weight?
"At vehicle separation, Starship’s upper stage successfully lit all six Raptor engines and flew a normal ascent until approximately seven minutes into the flight, when a planned vent of excess liquid oxygen propellant began. Additional propellant had been loaded on the spacecraft before launch in order to gather data representative of future payload deploy missions and needed to be disposed of prior to reentry to meet required propellant mass targets at splashdown."
Aren't they planning on a hover landing now? That would seem to be a nice solution to the problem of dumping the methane as well as disassembling the vehicle; run the engines in a hover until you're out of propellant. That should produce some nice engine RUDs. Though I guess they're RPDs at that point.The updated FAA impact assessment was heavily focused on marine impacts due to the belly smacker,.
Original plan to FAA was a smack down followed by the second and third burning up on entry. Since the IFT-2 had a heat sheild, the plan has changed. IFT-3 is doing a pseudo reentry burn, maybe it will try to hover also? Unfortunately, the launch licenses are light on details.Aren't they planning on a hover landing now? That would seem to be a nice solution to the problem of dumping the methane as well as disassembling the vehicle; run the engines in a hover until you're out of propellant. That should produce some nice engine RUDs. Though I guess they're RPDs at that point.
LOLOLThat should produce some nice engine RUDs
Contradiction in terms? Or at least a hemioxymoron??liquid oxygen propellant
