I am trying to remove the bench rear seat from my 2015 Model S, but cannot find a method which doesn't risk breaking something. I believe the seat is Generation 2, pictured here:
My research suggests the seat is secured by a pair of metal hoops at the seat edge engaging with nylon inserts in the seat base frame. Here are example pictures from a breakers web-site:
I cannot gain enough visual access to see my fixings, but these images are taken from the web, and I assume they are the type on my car. I am aware that the Model 3 uses a different mechanism, with a release lever.
Advice on various forums suggests that simple but firm lifting at the engagement point should do the trick - even saying that you may need to pull very hard. I have pulled as hard as a dare, but the engineer in me says any harder and I will break something - for which Tesla will doubtless charge me a king's ransom to replace.
Inserting a large-bladed screwdriver within the metal hoop between the seat and the frame might enable me to put a lot of purchase to separate the joint - but so far I've not been able to get the blade into the space.
I can find no pictures to reassure me that the metal hoops are securely part of an invisible internal frame in the seat, and not likely to break away from the expanded foam upholstery.
I would be grateful for the advice from anyone who has succeeded where I am failing.
Many thanks
Philip
Many thanks
Philip
