Rear tie rod ends--Lotus or custom?
ViperDoc
Roadster 1305
Jun 24, 2011
475
258
Vermont
My local mechanic says I need new Tie Rod ends for my rear wheels. He identified the part needed is on page 115 (one for each side) of the service manual.
#15, SPHERICAL JOINT, TRACK CONTROL ARM
Part # 2004808
Can anyone tell me if this is a Lotus part or some custom Tesla Roadster part? I want to get my hands on the parts quickly and last time I needed a front ball joint, it was a Lotus part and I was able to get one much faster going to Lotus directly.
Thanks!
David
No, it is a direct replacement. The Lotus had an upgrade that included the spherical rods and a cross brace to put the attaching bolt in double shear. The standard Lotus design used a regular ball joint type tie rod (with a 4 inch long stud to attach it) and was prone to failure during track use. The Tesla subframe uses the spherical ends with redesigned mounting to put the attaching bolt in double shear.
