I have a 2023 Model MP3 (probably built in 2022 at some stage), I can't figure how how to alter the Regen, I'm assuming now on 2023 versions you cant
Below appears in the Manual, does that mean there is no need to lower the Regen in order to clean the Discs going forward?
Brake Disc Wiping
To ensure brakes remain responsive in cold and wet weather, Model 3 is equipped with brake disc wiping. When cold and wet weather is detected, this feature repeatedly applies an imperceptible amount of brake force to remove water from the surface of the brake discs.
