MFrunkerOG
It’s been several weeks since the shower dam and the air intake sock. I’m pleased to report that despite several rainy drives, not one drop entered the air intake!
Hurrah!
Hurrah!
He told me like 3 weeks ago it would be 4-6 weeks before they would have them for sale.Has Anyone received feedback from Adam from the sock store?
Emailed awhile back and haven't heard anything.
Thats awesome! Great job hopefully finding permanent solutions. So far no smell on my model 3 or S and have also had serious rain storms. I’ve popped the frunk on both cars and there is water down the sides but the air intake appears dry so i think the Barrier is doing most of the work.It’s been several weeks since the shower dam and the air intake sock. I’m pleased to report that despite several rainy drives, not one drop entered the air intake!
Hurrah!
I don't think a new assembly is going to make that much of a difference. if enough water enters the air intake it's going to get the filter wet and then start smelling.I took my 2022 S in to the service center this week and they replaced the HEPA assembly, but the part on the invoice is 1750575-80-B not 170575-00-C. I asked what the difference was and they didn't know... he said he couldn't find 170575-00-C in their system but I clearly see it on Tesla's online parts manual and I can't find anything about 1750575-80-B. Does anyone know if this may be an issue or if, perhaps, it's the right part?
Yes I agree. The shower dam is probably the primary line of defense with the sock the. BackupI don't think a new assembly is going to make that much of a difference. if enough water enters the air intake it's going to get the filter wet and then start smelling.
I get that and I’ve installed the dam, a temporary pre-filter while I await the filterwears sock. I’m just wondering if the assembly is a contributing factor and, if so, if I have the wrong one. I noticed earlier in the thread someone had posted both part numbers and was told to go with the 00-C part which was $300 cheaper than the 80-B part. I never saw my original assembly but this assembly does appear to have some drainage channels before it hits the filter but it seems like the filter could still get wet, hence I’m going to still do with the dam and sock protection.I don't think a new assembly is going to make that much of a difference. if enough water enters the air intake it's going to get the filter wet and then start smelling.
What are you using for your pre-filter until the sock is ready?I love my teslas but damn this is annoying. Put the barrier in and then change the hepa filter and try to put a hydrophobic pre filter over the intake or wait for the custom sock.
A sheet of pre filter material from amazon taped over the air intake. Amazon has a few and I believe one from filter wears is available on amazon. It’s just a mesh screen that repels water.What are you using for your pre-filter until the sock is ready?
I should. Couple questions. Which post was the barrier info in? And did you try to salvage the filter by cleaning it out or drying it out?I love my teslas but damn this is annoying. Put the barrier in and then change the hepa filter and try to put a hydrophobic pre filter over the intake or wait for the custom sock.
I’m using this oneI should. Couple questions. Which post was the barrier info in? And did you try to salvage the filter by cleaning it out or drying it out?
I just got the s but had the issue in the 3 too so trying to prevent it. I think you need a new filter. I just replaced the filters in the 3 and added the same barrier and pre filter and so far no smell in either.I should. Couple questions. Which post was the barrier info in? And did you try to salvage the filter by cleaning it out or drying it out?
Is your intake the same size? 17” X 3.5”Silly Q. Would this also fit 2022 model X?
I’m too lazy to check. Very sad. I’ll check later and post back.Is your intake the same size? 17” X 3.5”
If yes, then yes, if no then no
