Hey all,
For the past few days I've been reading through all the threads related to this topic. With it being that time of the year now the inside of the car when inside of the garage exceeds 90F, which triggers the cabin overheat protection.
I had the overheat protection on AC (Big mistake, never have it on AC) within the app and I'm convinced that is the culprit responsible for the sour smell that has presented itself lately. A few weeks ago I changed the air filters anyway and gave the inside of the intake area a really good wipe down. (Did not use any cleaners).
I've since kept the air only on AUTO and have not experienced any foul smell at all. At times during the drive when looking at the air menu you can see that it turns on and off the circulation mode (outside to inside) so it's doing what it's designed to do.
I'm convinced that this is the key, to keep the air on AUTO and to let the car/algorithm or whatever you want to call it do its thing. By having it on AUTO it dries out the coils and if you have your destination going on the Nav, you'll notice that it switches it to outside air before getting there.
Definitely not rocket science, but it's nice to know that there is a working solution to prevent the foul smell. I'll also note that the smell issue is a lot less in the Y (better system), although it still occurs, but it seems the 3 with the dinky design is inferior, which makes sense. On a side note, I wish they would at least put the bio pre filter unit on the Performance model or at least have it an option, but that'd make things more complicated production wise so I get it.
Thanks for all the useful input.
Now let me ask, for those that prefer not to use the chemical sprays, what are your thoughts on spraying (spray bottle / mist) a mixed diluted solution of IPA >70% or Hydrogen Peroxide into the intake vent to help sanitize the funk? Since IPA evaporates quickly it should technically be okay? As for H2O2 the only issue with that is potential corrosion on metal fins? However, it would evaporate fast enough that it shouldn't be an issue?
The reason for using IPA or H2O2 is due to having a newborn and a small child. Just a personal preference, to each their own. I get that you blow out the vents with the sprays and all, but if there is another solution like the ones above that could do the job without any downfalls, then I'm open to trying that out.
Appreciate any input.
