Not sure what it is exactly, but there is somethig about the 3/Y front that even EVGarage at both their original NH location and the newer one near Amesbury MA, struggled to dial things in leaving the steering wheel slightly off center (either to the left or right) and then over-compensating in attempts to fix with too coarse side to side outter tie-rod adjustments.
Mind you this is all with true wheels, new or evenly worn tires, road force balanced wheel/tire combos, and undamaged, properly installed OEM or aftermarket suspension components, be it end links, misc arms or bushings.
At close to 6 years in, I have given up on dialing her in and expecting it to stick for even half a season (vs previous cars, which had everything from simpler to more complex suspension and steering setups and were 'easy' to align).
EV boutique shops and my personal 3/Ys aside, most Service Centers default to a horrible job, often skipping equalizing tire pressure and/or adding weights in the passenger seat/footwell before starting and usually barely touching front toe (and toe'ing it in or out too much) and calling it a day.
Last, lets not forget about the Hertz fleet of ill-maintaned and configured 3/Ys that sees everything from crooked to left, right, too loose at dead-center, unequal power steering assit bias, and damaged suspensions etc on brand new cars with less than 500 miles and beaten cars with more than 50K on their clocks. Sad.
Just look at all the 'related' threads that popped up below this one...
