Per my understanding when the car stops it applies the brake (thus you see hold on the screen), but if you touch the brakes again on a stop, the hold goes away, is the Car suppose to roll backward if on up incline (the car is still in Drive)? or if your on a down incline is the car suppose to roll forward when no hold is active?
I am asking because I did change my rotors recently to the MPP 400mm big kit which are slightly thicker, and I wanted to make sure the installer did actually compress the pads enough before installing back the caliber so they are not rubbing always against the rotor. I did not have the car for a long time so I am not aware of how it should behave. on my driveway (up incline) the car does not roll back on either Drive or Reverse when the hold is gone until I give it some go pedal, but if I put the car in Neutral it rolls immediately.
Thanks,
Thanks,
