Manually Releasing Charge Cable If the usual methods for releasing a charge cable from the charge port (using the charge handle release button, touchscreen, or mobile app) do not work, carefully follow these steps:I went through the Owners manual procedure for the manual release of the charge cord and can’t locate the release lever. Does anyone know if there’s a manual release lever for a 2020 MS? Thanks
Gotcha, that is the latest owners manual.Yup, went through all of that. I just can’t locate locate the lever and wondered if is one on a 2020
That’s looking upside down at the compartment
You can't remove the wand while push the release forward?I found the lever! But it’s no help
I'd say . That is really strange, if it is sliding then the wand should be able to be removed (is it just sticky? (had to ask)). Is there a support number on the supercharger pedestal or cabinets?Ok, it’s not a lever, it’s part of the locking mechanism that I can hear moving from outside. I’ve moved it forward and aft to it’s limits but the cord won’t release. This is a bit of inconvenience on a 2000 mile drive
This probably won't help, but I remember on my first road trip thinking the Supercharger cable was stuck and locked to the car for 40 minutes. It turned out to be just a much tighter fit than my home wall connector, or local superchargers. I wasn't familiar enough with the different colors on the ring back then, but if it's a light blue color, not green (charging) or dark blue (waiting to charge), it's not locked, and just requires a good yank.
In my situation, after getting nowhere with Tesla Roadside Assistance, another owner came to evaluate and gave a firm tug, which pulled it out fine.
I hope it gets straightened out sooner than that.So roadside middle says they have an opening middle middle next week. Good thing there are hotels nearby, right?
