Hi
Are there any rumors if Tesla is working on making the gen 3 wall charger with wifi, work with home automation systems ?
I have a solar system, which is integrated into Home Assistant, it would be great if the tesla charger would integrate into Home assistant as well, and one could control the charge rate, on the fly this way.
Would be trivial to set up automation to adjust charge rate, based on "Solar produced minus power used by house" This would maximize the amount of power fed to the car.
I have seen someone make som fidgety solutions with the load sharing feature, but it would be awesome if the charger just had an entity in Home Assistant where the charge current could be controlled.
So...Do we know if Tesla is likely to make the charger, do this, via wifi ?
