Tesla Model X two tone 22" factory Turbine wheels + Tires - $2900
These are factory 22" wheels with Pirelli Scorpion Zero Tires. Comes with all TMPS sensors and original Tesla center caps. These are the original silver wheels with custom cut decals in satin black designed similarly to Tesla's new two toned finish that they are releasing on their 2019-2020 models. This also gives the impression that the wheels are much larger than they are. These wheels come with an extra set of decals and as well and tire tread is included in the pictures. (3) of the wheels are in excellent shape with no imperfections at all. (1) wheel has very minor scratches which are included in the pictures as well. All individual wheels are pictured in high res to see exactly what you're getting. All tires have even wear and measured the same at 6/32. Here are the factory specs below:
Size: 22X9.0"(front), 22x10.0"(rear)
Offset: +35 front, +35 rear
PCD: 5X120
Center Bore: 64.1mm
Lug Nut Specs: 21mm, 14X1.50
Lug Nut Torque Spec: 129 lb-ft
Weight: 37.6lbs front, 40.4lbs rear
Price: $ 5,500.00
Details: The 22" turbine Wheel comes in two finishes Silver or Onyx Black. The Turbine Wheel is currently only offered When initially ordering a Model X for $ 5,500.00.
Tire Sizes: Front 265/35-22, Rear 285/35-22.
Bay Area, CA pickup only.
