External changes such as PTC or fuses have nothing to do with cell longevity and are not proof of automotive customized cells.
Positive temperature coefficient current limiting device and current interrupt device both mounted internally, within the cell. Sanyo, with a sheer amount of Tesla's order would modify cell line to be able to mount those.
It's quite possible those are standard options that anyone could order.
So now you are changing mindset to admitting possibility of customization by choosing options? No more Tesla buying cell from reseller? This indeed is a progress.
But those are not standard one. You can try to Google off the shelf 18650 cells, sure with so many brands available for sale online you would not have problem to find one? If you could, find one from Sanyo or Panasonic.
Your whole claim is that Roadster cells had "something" special done to them internally that extended cycle life, something that no one else at the time was using.
You have not read my posts??? I never ever claimed that there was anything
special done to Roadster cells. All standard practices.
Most likely Tesla was using additives, commercially available ones. To make sure Roadster will start up in freezing temperatures. To limit dendrites formation. Requesting specific particle size range for cathode material - to improve consistency/power density.
Once again, there are nothing special. Think of adding those chemical agents as an options. Sanyo or any li-ion manufacturer will have zero problems to do it.
I have said this probably 20 times, here 21st one: this is common practice in the industry.
The fact is that within a chemistry if you optimize for one parameter the other parameters are lessened.
I agree.
If you could just optimize for specific energy, longevity, C rates, and cost, all at the same time, everyone would. Which of those do you think Tesla was willing to sacrifice?
Sure cost, specific energy and C-rate.
Even adding PTC and CID would add to cost and lower cell's specific energy.
Adding antifreeze agent would lower specific energy and C-rate, while increasing cost. Laptop producer would not pay 1/10 of a cent per cell to ensure cell output power at minus 25 Celsius. Tesla might even pay half a cent per cell to ensure Roadster/Model S would start up at minus 35 Celsius (not sure about actual performance in cold weather, but someone here or on TM forum was actually asking about -35 Celsius). And such addition might add 1 gram per cell and -0.2 C-rate. Adding 7 kg to the pack total. Lowering C rate from 5 to 4.8. Or something like that.
Adding additive to lower dendrite formation - again might have a similar effect. Would laptop producer be interested paying extra for such option? As long as cells last 2 or 3 year, answer is
no way. Tesla need packs to lasts for 12 years...
Once again, this is all options, available to
anyone. Any li-ion manufacturer customer. No voodoo or other magic. Moreover, Sanyo or other cell producer do have scientists on payroll to help their customers to choose best formulation for specific need. Sure Tesla got their own team of chemists too.
But do not get it wrong, the combination of the options that Tesla have chosen are not sold by Sanyo on open market. And it is extremely unlikely that any laptop producer would be interested in cells tailored for Tesla.
Nowhere in those links does it say that tesla did or didn't use off the shelf 18650's. Tesla has made public statements that they used stock 18650 2.2 ah Sanyo cells many times. This is a known fact. You are arguing against something Tesla publicly stated many times.
So you are using PR department statements while I point technical docs?
Again, if you could not get tech docs, could you at least understand two phrases:
QUOTE: "
Tesla uses versions of this form factor modified for use in EVs. "
QUOTE: "
The cells also incorporate numerous mechanical, thermal, and chemical factors that contribute to their safety in the Tesla Roadster."
Tesla have not used off the shelf cells. Cells were modified for use in EV.
Both Tesla's statements. But unfortunately both docs are too technical for PR people to understand.
When you get this, you will understand that those PR department statements you are referring too are irrelevant to this discussion.
