Only been installed and running since Friday morning. my PW+ inverters have 3 strings: 1x 8 panels and 2x 11 panels, all individual run and not bridged/parallel. The strings of 11 are converted from PV wire to THNN in a roof J-box before coming down the conduit to the inverters.
Fri/Sat/Sun morning seem to be fine
Mon/Tue morning The same string of 11 is somehow getting disconnected to a "Not connected" status in the installer mode system page. The string was showing voltage/amp when i went to bed (low voltage and low amp, similar to the other 2 strings)
The shared variable seems to be that Fri/Sat/Sun are relatively dry and sunny morning, where Mon/Tue are rainy/foggy/moist/cloudy.
My other string of 11 is pumping 351v/3.13a but the "not connected" string aren't coming back up. I'm about to trigger a disabled/enabled to see if i can force it to come back online.
Anyone seen this before or have a fix?
