Hi guys, I have looked everywhere for information on this but I am not sure I've seen people with the issues I'm about to tell you all about. For background I have a 2020 M3 LR AWD with the 2020.40 software and I charge at home using a Test Wall Connector Gen 3 and at work I have a Chargepoint. I live in NY state where it's been in the 50's Fahrenheit in the morning lately. And I should say that originally the car seemed to charge/regen okay, but lately it has been a complete mess. So please read and "enjoy"
Taken together, I suspect that my battery management is not properly functioning and this is why it won't charge when "cold", why it can't estimate length of charge, and also why it will not properly allow regen. It's because it "thinks" it's much colder than it is. Any help would be greatly appreciated.
- When I schedule a charge for the morning it basically doesn’t work at all. It maintains voltage but the amperage fluctuates and barely charges at all. You can see a graph from TeslaFi attached and this is labeled "cold scheduled" and is second image.
- To test whether there was an issue with the scheduled charging, I also tested just normal morning charging. Had very similar results with constant voltage but fluctuating amperage and very little charging. This is labeled "cold charging" and first image.
- However, when I return from work and plug into the very same charger and charge I am able to charge relatively properly. This is labeled "warm charging" and third image.
- For comparison, when I destination charge at work after the car is somewhat "warmed" up it seems to work reasonably well. I have shown here a graph called "work charging" for that data and this is fourth image.
- Even when warm, the car still drops amperage as you can see quite a bit during the charges at home and at work. I am not sure if this is normal behavior or not but when the car is warm it will charge reasonably as expected.
- Lastly, even when the car is charging, it has no idea how long it will take to charge. This morning I was at work running at 6kW and 30 Amps. It predicted it would take 4 hours to get to 80% from a little less than 60%. However, 2 hours 45 minutes later it was done. Indeed, when it was at 79% it still said 30 minutes remaining even though it finished in just a few minutes after.
- There is a related issue with regenerative braking. I am aware that it needs time to warm up but I can tell you that even after driving about 30 miles yesterday in about 60 degree weather I never got full regenerative braking. And I often see the dashed dots to the right as well, saying I have limited acceleration. This happened this morning. At dead cold I had full acceleration but after driving 11miles I saw that I had limited acceleration. Doesn't make sense.
