Alto Nimbus
Er…what model Enphase inverter do you have? Newer ones should be UL 1741 SA certified which if you have a US profile applied means they're already configured correctly. If you have an older or misconfigured one perhaps that makes sense? UL 1741 SA certification means high frequency ride through is defined between 60.5hz-61.9hz for 300s and high frequency must trip is 62.0hz for 0.16s. https://aeesolar.com/wp-content/uploads/2017/08/UL-1741-Supplement-A_Webinar.pdf. Personally I've had Enphase apply the PREPA 83%/hz (Puerto Rico) which will start to curtail solar production at 60.2hz in an off grid scenario.
Thank you for this information. Sorry for the slow response. I Was battling irrigation issues.
I have theIQ 6 Plus 72-2 US inverter. It’s provisioned with the IEEE 1547 (2015) Grid Profile. The Envoy is running software version D5.0.34. June 25-19 build. It’s NEC 2014 and 2017 and CA Rule 21 compliant UL 1741-SA.
The inverters have an extended response range of 47 - 68HZ.
Do I understand correctly, that the Ride Through and Trip Frequency are applied by the Provisioning of the Grid Profile, which in my case is IEEE 1547 (2015 version)? A 2018 update exits, but has not been applied to my setup. This standard has 3 classes. IEEE doesn’t want to show me what the trip points are because the profit from selling the documentation?
Beyond this, there are also Powerwall settings that need to be adjusted, to solve the UPS and Microwave Oven not working.
I really appreciate your help in educating me in this area. It’s frustrating because I’m blocked from these settings in the equipment. Attaining the optimum configuration involves me cajoling Enphase and Tesla to make the changes, but this is the blind leading the blind.
Thanks again for your efforts to provide illumination.
Would you advise I also ask the the Puerto Rico profile, even though I live in FL? Would they even do that?
