I have had my Gen3 Wall Connector charging at 48A since it was installed. It's on a 60A circuit. Here's the info from the app (with the SN blocked out). It clearly shows it can output 48A:
But today I noticed the app shows the current limited to 44A with no way to go up to 48A:
The only thing I can think of is that the setup changed within the web interface. So I tried to connect to that. First I just went to the IP where I got this screen/error that I had never seen before:
Next I pressed the button on the cable enabling the built-in wifi and connected to that SSID. Then I went to the documented, built in management IP. Same screen as above. So I downloaded the Tesla One app. The only logical option on that app (after signing in as a non-tesla employee) was to"begin install" of a wall connector. It asked for the wifi info from the box, which I entered. It could not connect.
So for now, I'm stuck at 44A. Only other thing I'll add is that my electrician was here a couple weeks ago converting a 20A/120V circuit into a 20A/240v for a new single-head mini-split for my living room. He should not have in any way touched the Wall Connector circuit, but this is the only thing that has happened electrically-speaking since I noticed this 44A limitation. All that said, something tells me if I can get into the Wall Connector setup I'll find that it has been reduced to 44A and I can jack it back up to 48A. But I can't get in there anymore!
Any help would be much appreciated!
