I was teasing the front 15mm spacer and notice the wind noise significantly increase going 65mph +. any one notice it? assuming it should have the same issue with wider tire / wheel, feels like its effect the aerodynamic?
what do you except. You are putting wider tires on than what the vehicles was designed for. You create turbulence. and that creates noise.
Wider tires bring no benefit to the 3.
issue still there
not sure what else I can do to get this resolve, this might be the build quality from Tesla.
if I submit the service request for excessive wind noise, they are charging $150 to evaluate.
issue still there
You changed the aerodynamics of the car with the spacers. That's going to change the wind noise. Take the spacers out. If the problem goes away, well, here's your sign...
